Old 9-Mar-2010, 5:50 PM   #4
mtownsend
Thanks for the report!
It looks like the transmitters are not that far away, but they are partially blocked by some hills along the way. The good news is that it looks like you have many channels within reach coming from a single direction.
To make the most of the signals available, I would recommend a medium to large antenna on the roof and a pre-amp. An indoor or attic antenna is not going to be good enough. For antenna, mount, mast, pre-amp, and coax, I think you're looking at an investment in the neighborhood of ~$200-250. I think you will get a lot of channel choices in return. Does this seem reasonable to you?
