I recommend the Winegard HD7082P , aim the antenna at about 255 magnetic compass. Try the reception with out a preamp or distribution amp connected to the 2 Tv's with a 2 way splitter. If a little more signal power is needed to get signal thru the 2 way splitter and lengths of coax , down the channel lineup to WRTN 17 , with the 2 Tv's connected. Then I suggest a Winegard AP8700 preamp. Channel 38 is a strong channel and will be received. I suggest a Strong and Sturdy antenna mount such as , tripod antenna mount , chimney mount , peak of the roof eave mount.
