Old 2-Apr-2011, 5:34 AM   #1
Yaguy
RE: Cross-hatch type Interference
I hooked up a new Zinwell ZAT-970A digital to analogue converter box and noticed that there are diagonal lines going arcross the screen from left to right: ////. (The picture is clear but the interference is about the same on all channels.) It might be called Cross-hatch interference. It is constant and the lines are about 1" apart on a 27" CRT Toshiba TV. Is this a symptom of bad coax or water infiltration, antenna age, or just a radio frequency, be it FM or another band that the outdoor combination VHF/UHF/FM antenna is receiving? It is a Radioshack RS VU-160XR. I just would like to know if anyone here has had this type of interference or knows what it might be and how to eliminate it as much as possible. Thanks.
Yaguy is offline   Reply With Quote
