Tv Antennas and Reception
Is the building where the the Tv And the antenna are at a , house , condo , apt. , mobile home , motor home ?? The following reduce Tv reception when the Tv antenna is on the inside of the building , Is the building wrapped with but not limited to , metal siding or stucko with stucko Wire ?? , brick from ground to roof , metal foil backed insulation?? , metal roof ?? , solar panels on the roof , poured concrete walls ?? ,
