You misunderstand completely what we try to do here.
The TVFool charts provide three key pieces of information: what gain is required, where in azimuth it is required, and at what frequency (channel) it is required for each station that can be received. Once all the gain requirements are put together, the complete specification for the antenna system is known. We then try to find the most reliable and economic antenna system recommendation that will fulfill the requirements. It is certainly NOT just stick antenna x in the air and best of luck to you.
