Television Reception
Looking at the >>Start MAPS<< part of tvfool. I have a suggestion , long ago when broadcast television was the only way to receive television it was common practice to move the antenna around in all directions so as to receive reflected signals. Pointing the front of the antenna up or down and even tilting the antenna to the left or right from the horizontal plane in to the vertical plane to receive reflected signals off of surrounding mountains or through canyons , moving the antenna around to find hot spots. I see that there is a very tall mountain to south west of the town of Bailey Colorado. If you have a Tv with a digital tuner that can manual select digital channels without scanning or a seperate digital tuner that can manual select digital channels with out scanning , this will be a big help. Please note that with digital tv there is such a thing as Virtual Channels and Actual Channels , KBDI is an example , the Virtual Channel is 12.1 , 12.2 , 12.3 , the Actual transmitted channel is 13.1 , 13.2 , 13.3
