From thread 1504
...but the only channel i have problems getting is 23.1 cw???
also city tv is fuzzy...
The next steps to try would be:
- Connect only the SE facing antenna. Then check to see if WNLO (real CH-32) is received.
- Connect only the NW facing antenna. Then check the reception of CITY (real CH-57).
If one or both problem channels are improved, you may need to reconsider the use of a reversed splitter. As I mentioned earlier, " In most situations, the result is less than hoped for." A/B switching is technically sound, and likely the least expensive option to consider next.
