The reasons that I recommend all channel antennas is that longer elements at the back of the antenna reject multipath at the back of the antenna better then a 7 thru 69 antenna , the longer elements toward the back of the antenna increase forward gain , the longer elements toward the back of the antenna reject multipath at the sides of the antenna better , The longer elements toward the back of the antenna make for tighter forward reception. So Yes it is a reacuring theme and pattern and Yes you will be reading it again and Yes you will read the explaination again.
