Originally Posted by Dave Loudin
... The first thing I'd try is changing the tilt angle back to exactly vertical before anything else. You should then try raising/lowering the antenna in place before searching out a new location.
@ DL: Agreed.
@ PhayenK: If reusing a satellite dish mount, beware of the OTA antenna being so low that it is aimed into the roof, a source of signal reflections and attenuation.
I would expect the dish mount to be on the south side of the building... you are aiming at stations NNW of you. I can't help but wonder if your roof blocks the line of sight toward Mt Wilson.
