WJLA is the lowest frequency (RF 7) station that you are trying to receive. Generally, lower frequencies need larger antennas to work well. Yours is a small antenna that uses a strong internal amplifier to compensate. I do not see what else you can do except to raise the antenna higher to see if you can catch more signal. Your best bet is to find another antenna that is designed for both VHF and UHF without having to include an amplifier. The moderator has some solid suggestions.
