Thanks for all the quick responses. It was annoying how I get all the channels on the same path.
As for the mount, I'm just using the satellite dish's location. I had a spare piece of medium gauge steel tubing that I drilled some holes in to mount the antenna. Its mounted at a slight angle, but it looks like its supposed to be a little.
I'll try a different spot and see if that helps.
Thanks everyone!
