Old 29-Mar-2011, 8:08 PM   #13
Sarge
Thanks again. I'm certainly learning a bit more than I anticipated including, different websites have different descriptions of the same product.
The 7084P looks like a good choice and Winegard.com lists the following:
HD7084P (VHF, UHF)
28 VHF Elements, 40 UHF Elements
Mileage: 0 - 60 Miles*
Channels: Low & High VHF, UHF (2 - 69)
So it looks to pick up all the way down to channel 2 which would save the channel 5 that I currently receive.
In my efforts to try and pin dwon the best choice, I also looked at the Channel Master CM 3020 which had the following info:
The Channel Master CM 3020 is an outdoor TV antenna which will allow you to receive UHF, VHF, FM and HD signals. This antenna has a signal range of 100 miles and will pick up available local channels 2 thru 69.
• Reception Range: Channels 2 thru 69 up to 100 miles
• Picks up UHF, VHF, FM and HD
• Antenna Size: 152 x 95 x 22 in
• Superior signal strength in weak signal locations
They're fairly close in size and I could fit either one. Does anyone have any thoughts between the Winegard 7084 and the Channel Master CM3020?
Sarge is offline   Reply With Quote
