Originally Posted by Sarge
My only concern with going to a 7-69 antenna, if I'm reading things correctly, would be the loss of WTVF which is a low power VHF with a Real channel of 5 and Virtual # of 5.1. That is one of our local stations that comes in quite well, even with a cheap antenna.
WTVF appears to be moving to UHF 25 eventually. No idea of their schedule although they have the construction permit issued by the FCC. If WTVF comes in with a "cheap antenna", you can always keep that antenna for as long as needed and use it for VHF-low only by diplexing it in with an HLSJ.
I spoke with Winegard who said the HD7697P is 2-69. Not sure if they were correct or not.
Double YIKES!!!!
