Tv Antennas and Reception
I agree with GUM about the 2 antenna set up. Each antenna is connected to a 2 way splitter and the outputs of the 2 way splitters go to the the Tv's. DO NOT combine both antennas on to the same coax at the same time. Use a remote control A/B antenna switch at both Tv's to switch from one antenna to the other. Here are remote control A/B switches , ab27rs and rs 15-1968.
