Thanks for the quick reply. Fitting any of those would be a bit tight and not sure if I could rotate them. I was thinking of something like the HD Stacker which is a bit smaller and I could easily rotate (if it comes with one). However, no idea if that's a reliable antenna. Also, when I checked the HD Stacker, it only received channels 7-51 whereas some of those you mentioned are 2-69.
Reason: typos
