Old 28-Mar-2011, 11:17 PM   #1
MikeInRI
Local Reception Challenge ... the attic.
Hi,
First off, I just found this site a few hours ago and, WOW, what a great set of tools!
My project is to improve reception on two TVs for several local channels while not affecting the good reception I have on other channels.
http://www.tvfool.com/?option=com_wr...8d177350d0a3b1
Here is the layout. It's a two story house:
TV-1 HDTV on the 1st floor with a Terk rotating set top antenna.
TV-2 HDTV is in the basement being fed from a rooftop 20" round Radio Schack antenna (non amplified) pointing to 20 deg. The cable from it goes to a wall connection in the basement then from there a short Sony "injector cable" connects from the wall to the TV. The injector is just a compact signal booster and it does help with the reception on this TV.
Current Reception (both TVs have similar reception):
The reception from 20deg is very good, although 32, 39 and 41 pixelate randomly as well as in poor weather. If possible, I'd like these improved.
From the report, I don't really care about channels below #41.
Almost all the channels from 105deg need to be improved. They have various levels of pixilation in good and bad weather. The house is on the side of a hill near the top. There is a clear site to 20deg BUT in the 105deg direction, the hill rises for a while then drops away after a few hundred yards.
Plan 1 is to put an upgraded antenna system in the attic that serves both TVs. It's a standard wooden roofed attic with asphault shingles and no metal or insulation. It can afford only about 24" of height for an antenna. From reading through the forum posts and the report, it seems there may be enough NM(db) headroom to afford an attic installation. ... hopefully.
I would greatly appreciate any advice on this and the appropriate wiring stye to the first floor and basement.
Best,
Mike
MikeInRI is offline   Reply With Quote
