Old 28-Mar-2011, 7:01 PM   #4
rickyp816
Thank you GroundUrMast and ADTech for the quick reply and links. It's appreciated! If I understand, basically the new antenna isn't as good with low VHF as the old one?
I assume since my HD-1080 picked up Channel 5 reliably (6 of 6), I should be able to use that as the "low" portion of this dual antenna scenario?
ADTech, wouldn't the HLSJ filter out any UHF signals from the 7-69 antenna? That's why I thought you'd use the UVSJs. If I'm wrong, I can certainly try without them, but just want to make sure.
rickyp816 is offline   Reply With Quote
