Old 27-Mar-2011, 9:54 PM   #4
WeAreNotAlone
To make sure we all understand...
You now have all the channels you want except WPXH (real CH-45) and WTJP (real CH-26). Yes?
Re: You now have all the channels you want except WPXH (real CH-45) and WTJP (real CH-26). Yes?
YES.
WPXH (real CH-45, 44.1 ION 1st edge@29.7 miles, 33 degrees) and WTJP (real CH-26, 60.1 Ind, 1st Edge@26.2 miles, 42 degrees) have alot of good stuff- so need a solution for them.
(With the RCA ANT751 pointed towards 225 degrees the only channel that might be iffy is ABC 33/40 (real ch-33) 33.1 (@39.2miles out @265 degrees) which is also broadcast on (real ch-9) (virtual channel 40.1 @ 20 miles)
And, the network attached tuners are seeing usable signals with the above exceptions. Yes?
The Silicon Dust HDHomeRun tuners have NOT been tested with the RCA ANT751 pointed towards the strong stations coming from 225 degrees (4.6 miles).
(IIRC, In the past when I had the HDHomeRun tuners connected (thru the old antenna- and maybe thru the RCA ANT751 pointed AWAY from 225 degrees) they were "picky" about having a good signal fed to them and were pretty much UNUSABLE.- so they haven't been hooked up in a while. With that said the computer used as a media center was originally running MCE_2005- and due to a failed HD I was going thru codec hell. Before the ASTC change-over via the computers built in analogue tuner tuner worked PERFECT. Upgraded various components, migrated to Win7 which got rid of the codec issues- bought a totally new machine-still problems.... Now with a brand-new antenna/cabling it *should work.)
The only devices connected currently are the HDTV sets built-in ASTC OTA TUNER and a Dish/Echostar DTVPal Plus OTA SD 480i tuner box.The DTVPal's main function is it has a "GUIDE" showing upcoming shows.
Getting the network attached HDHomeRun tuners (2- each having 2 tuners- for a total of 4 tuners) is a major concern so A: content can be recorded and viewed later, and B: So we will have a GUIDE again....C: Be able to view on other devices
*Note the SilconDust HDHomeRun tuners do NOT have internal bridge /splitter- Each tuner has a separate input.
Additionally I would like to distribute the signal to Kitchen, other rooms in the house. Currently the house has NO distribution network.
Do you care about real CH-7 or CH-9?
CH-7 No, and CH-9 *No...
CH-7 (PBS) @ -1.4 db is:
A: A duplicate of WBIQ (PBS) 69.6db LOS @4.6 miles, 225 degrees so NO.
B: @ -1.4 db is too weak to be picked up from everything I've read- From what I've read you want to be in the +10-15 db range and above after adding in cable/splitter loss.
CH-9 (40.1) ABC is also broadcast on 33 (33.1) (@39.2miles out @265 degrees). Jury is out on usability of 33 (33.1), so far so good but @39.2 miles out I'm assuming it's going to be a borderline station (At least with the RCA ANT751 as it's a smaller antenna)
WeAreNotAlone is offline   Reply With Quote
