Old 27-Mar-2011, 6:37 PM   #6
Originally Posted by Dave Loudin View Post
GUM, don't knock the GH for high VHF. Done properly, designs are showing at least 7 dBi gain in that band.
Duly noted.
Originally Posted by Javaman View Post
... A 10 dBd gain should do it for channel 10 shouldn't it?
I have built several antennas myself... so I certainly won't discourage others from the hobby. There is the theory, and then the practice. With out expensive test gear I can only use crude build, try, compare methods to determine real performance.
10 dBd should give you access to CH-10 and 11. On paper, it says 9.8 dBd... YMMV
Wishing you success!
