Tv Antennas and Reception
If are using indoor tv antenna do not split the signal from 1 indoor tv antenna to 2 Tv's. Use a separate indoor antenna for each Tv. Both of the indoor antennas can be upstairs where the signals are strong , from one of the indoor antennas a coax cable can be connected to the downstairs Tv if it is a fairly short run of coax. You can also have one of the indoor antennas downstairs and have the indoor antenna close to a window that has more exposure to the Tv transmitters. If you go with a outdoor antenna on the roof then use the coax wiring in the house with a 2 way splitter. A amplifier will not be needed with the outdoor antenna. DO NOT connect the antenna or antennas to the coax wiring in the house if it is connected to cable tv companies active cable line or satellite Tv.
