Old 24-Mar-2011, 7:05 AM   #6
John Candle
Tv Antennas and Reception
You can put a indoor antenna on the 2nd floor in a location where the Tv transmissions are strong and run a coax cable down to the location of the Tv on the first floor. It also helps to put the antenna at a window that has more exposer to the Tv transmitters. . If you will install a roof top Tv antenna such as a simple small Winegard HD7080P all channel antenna or Channel Master CM3016 all channel antenna or Antennacraft HD850 and point it at about 10 degree magnetic compass you will receive the Tv stations to the , north west , north east and south east.
