Old 7-Mar-2010, 12:56 AM   #1
rivernut
Preamps & reception
You guys advised me back in October about the correct antenna setup, for which I am eternally grateful considering I don't know squat about this stuff. Just finished building the house I'm putting this rig on, so am about to begin acquisitions of equipment. My signal analysis: http://www.tvfool.com/?option=com_wr...b671eac3f755c7. OK, you said get a Winegard HD-7696p ant., a Winegard HDP-269 preamp, and a Channel Master 9521a rotor. Cool! I look at my list of stations I should be getting at that location and there are several that are yellow, then somewhere I read that one should amplify the yellow atations. True or false? Also, I am in a location where hopefully I can pull in some of the boatload of stations in grey(farther away). That preamp has 12 db gain, is that sufficient or too much for the closer stuff? Thank you again for your help and recommendations!
Just trying to understand alot of this stuff before making a large purchase soon.
rivernut is offline   Reply With Quote
