Old 22-Mar-2011, 2:35 PM   #8
musky
Combining two antennas with a common splitter may work. In most situations, the result is less than hoped for.
The up-side is; It won't hurt anything to try. If it works, it's cheap and you get to brag to all your friends.
The down side; You may loose some channels or make them unreliable.
If it fails, consider using an A/B switch.
ok i tryed the splitter and it worked fine thanks....except city tv is a little fuzzy..is the anything i could get to boost singals,also if i wanted to run it to 2 tv,s.
musky is offline   Reply With Quote
