The HD7697P antenna is long , if it will fit in the attic then try it in the attic. If you decide that the attic is not working well enough , The Winegard HD line of antennas are very Strong and Sturdy and with a Strong and Sturdy antenna mount such as a tripod mount or chimney mount or peak of the roof eave mount , the antenna will be in good working condition for a long time. . I recommend connecting the Tv's to the antenna with plain simple 2 way or 3 way splitter to begin with and see if can receive channels down to digital channel KXLY-TV 13 ABC. If a little more signal power is needed to get KXLY to 2 or 3 Tv's then I recommend a Channel Master CM 3414 distribution amp. . Not a preamp. . Be sure and use 75 ohm terminators on any unused output ports of the distribution amp.
