Old 20-Mar-2011, 11:13 PM   #5
fukukita
Your TVF report was generated at 10' AGL. If you will be mounting at a higher elevation, can you generate a new report at the actual antenna elevation?
The present antenna is about 12 ft AGL. I generated anew report but the numbers changed very little.
I am reluctant to install the antenna outside on the roof as my house experiences high winds at times. Street's name is "viento" which in spanish translates into "wind".
fukukita is offline   Reply With Quote
