Old 20-Mar-2011, 11:04 PM   #4
fukukita
Originally Posted by John Candle View Post
You have 5 outlets in the house , how many will be actively used ?? What is the Tv wiring being used through out the house ?? If any of it is the old twin lead then it will need to be replaced with RG-6 coax and if it is a combination of this and that other wiring it will need replaced with RG-6 coax. I recommend a Winegard HD7697P antenna pointed at about 340 magnetic compass. . To find out if a amplifier will be needed , how many Tv's will be connected ??
The original antenna wiring (more than 35 years old) in the house is coaxial type. The old antenna has a twin lead connections which was then connected to the amplifier by coaxial. I also have access to the satellite wiring system which is RG-6 which I plan to use. Of the five outlets, three will have TVs conencted although only two will be used at any one time.
Many thanks for the antenna recommendation and advice on compass direction.
fukukita is offline   Reply With Quote
