The ANT-751 will do quite well if mounted outside, with a reasonably clear view to the NW.
The questions regarding the construction materials will be relevant if you opt for an indoor antenna.
The building construction becomes far less an issue if you install outdoors. The strength and more importantly, the quality of the signals will almost certainly be better with an outdoor antenna.
TV Fool offers incredibly easy access to signal predictions with outstanding precision. What works for your neighbors may or may not work for you. The antennas most commonly suggested here, are well documented buy the manufactures. It's usually a fairly straightforward process based in the laws of electronics / physics that enable us to match an antenna to your unique signal conditions.
