I think of the mast ground as step one, the coax ground as step two.
Ideally, the mast ground would connect to the ground rod that is closest to the electrical service.
Ideally, locate the coax ground block close to the same ground rod that is closest to the electrical service.
(You can use the Tivo box signal meter to fine tune your aim.)
