TV Antennas and Reception
Even so , is the CM3010 the amplified version or non amplified version. Unpluging a amplified antenna does not make it in to a Nonamplified antenna. Every time a split takes place the signal is reduced. It is best to simplify the coax wiring so that there is Minimum number of splitters. Do Not use amplifiers, use a bigger antenna. Bigger antennas collect more signal. Amplifiers Do Not collect more signal. I suggest a Winegard HD7697P antenna.
