Old 18-Mar-2011, 11:01 PM   #4
IGeeky1
OK, I have replaced twist-ons with compression fitting. Little change.
I am getting virt 49,17,55,5,8,43
25- CM7000 detects 25.1-25.4 yet I see no visual
34- get sometimes other times not
I feel I should be able to get both 3 and 19.
Antenna is http://www.channelmaster.com/HD_tele...tenna_s/53.htm
Coax RG6 quad cable no amps. Furthest desired channel is 25 miles, antenna rated for 45 and I'm getting some channels in fine with the same distance and signal strength ratings. A single TV
As per channel 10 on VHF - I am getting 8 so I should be good there.
Thanks everyone
IGeeky1 is offline   Reply With Quote
