Old 17-Mar-2011, 7:19 PM   #3
manolo
Please tell us a bit more...
Are you using a newer television with DTV (ATSC) tuner built in or a set top box converter? (Make and Model please)
Have you set the tuner to receive over the air 'antenna' signals as opposed to cable?
Are the Canadian channels coming in 'crystal clear' or somewhat snowy, or looking like they are being interfered with in some way?
Mounted outdoors, the ANT-751 should be able to receive US stations, though based on your answers to these questions, a different antenna may be indicated.
I just purchased the television, it's a Toshiba 40G300U with tuner built in.
The TV is set for antenna.
I get them all coming in the lowest I have is two bars for CTV(12.1) and CBC(6.1) at one bar. All digital crystal clear and analog as good as I have ever had.
I had tried one of those quick youtube antennas a couple of days ago and had the US channels coming in, but lost them as the antenna fell over.
Would I need two antennas or one would be okay mounted outdoors?
I was thinking of doing an attic installation?
Thanks,
manolo is offline   Reply With Quote
