John's antenna suggestions cover all channels.
According to RabbitEars.info, WNDC-LP on real channel 2 is owned by "HISPANIC CHRISTIAN COMMUNITY NETWORK, INC." I have not found any more information.
On real channel 6, there are two stations indicated, making receptions questionable.
If you would like to receive channel 2, use one of the options John is suggesting. If you have no interest in channel 2, a 4-bay panel antenna such as the Antennas Direct DB-4 (Antennacraft, Channel Master and Winegard each offer an equivalent) would provide good reception.
(As I understand the FCC rules, there is a limit to the size of satellite dishes, 1 Meter in diameter. But OTA TV antennas are not limited to 1 Meter... I'm not an attorney.)
