Your antenna is a good choice... so many consumers make the mistake of buying an amplified antenna. The signal levels at your location would overload most amplifiers.
Try moving the antenna to window with a view to the NW. Be sure the window does not have a metal screen.
This may require a section of RG-6 cable and a barrel connector.
