TV Antennas and Reception
Even though I am recommending the HD7697P antenna , the HBU33 should be getting many many many channels. Is the antenna pointed down at the ground ?? Up at the sky ?? Is the antenna horizontal with the ground ?? The antenna needs to be horizontal with the ground. Do not use any of the satellite connection hardware such as splitters , amplifiers and etc. . Out door Tv antennas need breathing room / elbow room. The antenna needs to be clear of obstructions , the best place for the antenna is above the roof of the house and away from near by trees and other obstructions that are in the direction of the Tv transmitters.
