Old 16-Mar-2011, 11:21 PM   #7
Originally Posted by snkfelker View Post
I will look into these suggestions. Thanks so much for your help. So if these things all seem ok, are you suggesting that we do not need a preamp based on the report and the antenna that we have?
The HBU-33 should be able to recover enough signal to drive one set though 100' of RG-6... All the way down to WIRE-CD real channel 40 on your TV Fool Report.
An amplifier is not indicated.
I would do a thorough inspection, substitute a known good balun, add an FM trap and reconsider the mounting location and height... All before considering the amplifier option.
