Old 16-Mar-2011, 2:14 PM   #9
Tower Guy
Originally Posted by Red_48 View Post
Will I have to replace the antenna too?
Three of the elements are not properly locked in place. You may be able to lock them in place with a long pole. If they don't lock, the plastic mounting brackets may be broken. When you're done it should look similar to this:
http://www.winegard.com/kbase/upload/HD-7015.pdf
The antenna model is not an HD-7015, but it's very close.
The antenna is appropriate for your location. Yet, if you can't fix it, a new HD 7694P would work fine.
