Old 13-Mar-2011, 4:50 PM   #3
jmfsms
Results of Trying Steps...
Thanks for the help, I really appreciate it. Sorry I did not mention the tv type it is an LG Model 55LH40.
Doing the reset did not help and I contacted LG who told me that the set top converters (Access HD Model DTA1080U) had a better amplifier than the tv which they stated (I'm not lying) had a weak one.
I tried to explain that it did not make sense as all other sub-channels came in fine and I told him about a possible TV set firmware incompatibility with the data that is being transmitted by WTBS/WANN but they did not like that idea either.
They did agree to upgrade the firmware of the television due to another issue with lipsink and picture with this set.
I am thinking of trying a stronger antenna just to see if it helps any suggestions on which would be best to try? Currently the one channel I do not get is channel 8 PBS out of Atlanta and I thought maybe a dual setup would do this and my channelmaster 7778 allows for the two antennas.
Also, I am e-mailing the engineering department for WTBS/WANN to see if they can give any input.
Thanks for all the help, jmfsms
jmfsms is offline   Reply With Quote
