Old 13-Mar-2011, 4:31 AM   #1
jmfsms
Sub-Channels Problem
I live outside Atlanta Georgia and pickup channel 32 which has 20 Sub-channels all of which come in clearly on my flat screen tv except 32.3 (thistv) and 32.4 (prism). This occurs even though the antenna is only hooked to the tv with no splitter. With the splitter, I run to a second older tv with a converter box and I get both of these channels fine. I have tried replacing the cable wires and all wires used are RG6. Here are the specifications of my setup and any help is greatly appreciated....
tvfoolreport: http://www.tvfool.com/?option=com_wr...597996507fd0e5
antenna type: clearstream4
preamp: channelmaster 7778
I also have a regular amp which I can add but I still do not get 32.3 or 32.4 on the new atsc ready tv. Oddly enough I do not get the same two channels on 26.6 or 26.7 which also broadcasts them fine on the old tv with the converter box and sorry to be redundant but I have already tried switching cable wires. Ugggghhhhh....
jmfsms is offline   Reply With Quote
