Old 12-Mar-2011, 2:21 PM   #1
gasalisbury
Antenna Recommendation Request
I am looking for antenna recommendations. I wish to view FOX, ABC, CBS, and NBC and FM would be a nice to have but not mandatory. If the antenna solution provides reliable reception, I will connect to a PC/Home Network that I will would like to use as a DVR so I will assume the PC will not be able to actuate a rotor (although someone probably figured out how to do that!). Would prefer to mount antenna in attic but will do roof mount if necessary. I used accurate GPS coordinates to generate the report: http://www.tvfool.com/?option=com_wr...59794a837bf56a
I requested help from channel master. Their response:
I would go with CM-4228HDs if you are not concerned with FM radio, if you want FM radio you could go with one CM-3018 to pick up FM and use a 4228HD facing the other direction. You can use a two splitter to combine both of these signals in which you should then run the combined signal through our CM-7777 amplifier to boost the signal, then the RG6 coaxial would route into your home.
Can anyone confirm this recommendation or offer additional help? Sharing of your expertise would be greatly appreciated.
