Tv antennas and Tv reception
The hd stacker antenna restricts reception to the UHF part of the antenna because of the VHF high antenna that is directly on top of it. There is a loop wire in between the two parts of the antenna that is a phasing loop. It is held in place by plastic supports , when the plastic supports break the wire will hang down , this will effect reception. If the wire or wires break , this will effect reception. If the wire is hanging down , do not tape the wire to any metal parts as this will effect reception. If the phasing loop of wire breaks and is missing , do not connect to short wires between the two antennas , this will effect reception. . I Never Recommend the hd stacker.
