Tv antennas and Tv reception
If the UHF antenna is pointed at about 342 magnetic compass and is not getting all the stations you will like then I recommend a Winegard HD7694P Tv antenna pointed at about 342 magnetic compass. Connect the HD7694P antenna with No preamp at first. Do not have any splitters connected , splitters reduce the signal each time a split takes place. You will not receive every Tv station out there. Your receivable Tv channels are in the VHF high channels 7 thru 13 and UHF 14 thru 69. You can also try the preamp that you have. If the preamp that you have does not work well enough then I suggest a Winegard HDP269 preamp. . Here are places to buy Tv antennas and etc. http://www.solidsignal.com , http://www.3starinc.com , http://www.starkelectronic.com , http://www.amazon.com
