Tv antennas and Tv reception
The Tv transmissions at your location are strong. Do not use any type or kind of amplifier. The CM3010 has less gain on the UHF channels then the CM2016 , the VHF gain is about the same for both antennas. The UHF directional reception of the CM2016 is better then the CM3010 because of the the long boom of directors out front. . . The signals are strong at your location and the antenna does not need to go over the top of a three story house. Would it be possible to shoot around the house?? Move the Tv antenna so antenna looks around the right or left side of the house??
