Would I receive significantly more channels by installing this older antenna outside, and or would a new antenna bring in more channels to make it worth the cost?
I have older antenna found in attic: used 300 - 75 ohm balen's to UHF/VHF combiner, to RG6 to set. Now receiving 8 channels, 4 of which in HD. The older antenna is typical christmas tree design (no name), with longer rods on one end, narrowing to flat type atenne on opposite end. Second antenna has two circular rods, one smaller, and long single rod, with rods that flatten at the ends.  This antenna is mounted in Attic, which I could move outside, and gain approx. 10' in elevation.
Looking at my analysis tool, I beleive I should reasonably be able to receive approx. close to # 25-30 channels, excluding all other complications(interference, tight connections, etc.)
Analysis Tool:
http://www.tvfool.com/?option=com_wr...1da952cc24d250
