The CS-5 will do well covering the VHF channels, particularly 7 through 13.
The CS-5 is not a high or even medium gain UHF antenna which is a bit of concern given the long list of stations on real channel 14 and up, most with 1 and 2 edge paths as well.
If you install the CS-5 and find it not quite enough antenna, will you be open to the idea of adding a second UHF specific antenna?
Or, go with a combination UHF / H-VHF such as the Winegard HD7694P and get the coverage and gain you need to have stable, reliable reception at your location. It is smaller than the former 'all-channel' antennas because it omits coverage of the low VHF channels 2 - 6.
