Old 10-Mar-2011, 12:51 AM   #8
rgallop
Today I received the AD DB2 and so far I wonder if I am doing something wrong. I mounted it near the NE corner of the house and hooked it up. I didn't have time to adjust it so it's pointed toward the ground, but quite some distance out since it's about 10 ft. up. I will re-adjust on Friday when the weather is warmer. It's 36 cloudy and windy in Kansas City today.
Anyway, I am getting bouncing reception on most of the channels. I did a rescan on 2 of the 4 tv's and it's basically the same results. One thing I may need to pick up tomorrow is an RG6 cable. The one I used from the antenna to the 3 way splitter is an RG59. I've had it in a box since we moved a few years ago. Should I replace the cables from the splitter to the converter boxes as well? They worked fine recently before we dropped Comcast.
I am open for suggestions since I want to make this antenna work correctly.
Thanks,
Rob
rgallop is offline   Reply With Quote
