Thread: Antennas
Old 9-Mar-2011, 10:00 PM   #4
Tower Guy
Originally Posted by kmmd11 View Post
Should I use the old style (normal) or a bow tie?
I'd suggest this Grey Hoverman design:
http://www.summitsource.com/antennac...le-p-6356.html
It gets you the UHF gain of an 8 bay UHF and the broad pattern of a 4 bay UHF. This helps because your critical UHF stations range from 155° to 177° and are not that strong. A rotor would add flexibility, including reception of some Boston stations.
With both WWLP and WENH on channel 11 neither of them are likely to be 100% reliable unless you stack a pair of VHF antennas 1.5 wavelengths apart (7' 3.5") horizontally.
