Old 9-Mar-2011, 12:34 PM   #1
justrussell
Rotator w/ TV tuner help
Hello all, great board.
I've installed a new antenna with rotator set up over the last week. It's a pretty slick setup. Yesterday, I finally had time to mess with the rotator and figure out how to use it. I'm about in the middle of Indianapolis, Louisville, and Cincinnati. I point the antenna toward Indy, and do the auto scan on TV and get a ton of channels. Then i point it toward Louisville do the auto scan and same thing. Here is my problem: when you do the autoscan for each position of the antenna, the tv gets rid of the channels found in the previous position. There is a manual entry area, but tv says this only works for analog. They're right, if i haven't ran auto scan, and point toward Indy and manually enter "8" or "8-1", nothing.... run autoscan and there it is.
Do I need to buy some kind of tuner box? or what do I need? Someone else has to have had this problem too....
Oh, my TV is a Sylvania 42 inch plasma 6842THG
Thanks for any advice.
Russell
justrussell is offline   Reply With Quote
