Television reception.
Is the building wrapped with any type or kind of metal siding?? Are the walls poured concrete?? Is the out side of the building brick?? Does the building have foil backed insulation?? Does the building have a metal roof?? Are there solar panels on the roof?? The Tv transmissions that are LOS Line Of Sight are Strong , an amplified antenna is not needed.
