You're going to need to build big.
If you can consider installing a tower or tall mast, it would be interesting to see what the signal predictions look like at higher antenna elevations.
If 25' is the highest practical elevation, I would recommend an Antennas Direct XG-91 for the UHF (14 - 51) channels and a Winegard HD5030 to cover the VHF (2 - 13) channels.
I would go with a CM7777 preamp that has inputs for each antenna.
