You have plenty of signal in the air... I would mount an Antennas Direct DB-2 or DB-4 outside. Facing NE, you should not need any amplifier for a system split four ways... It's not clear to me, how many total receivers are connected though. I would try with out amplification, a high input amp won't be difficult to install later. The larger DB-4 would provide power for more signal splitting.
Antennas inside or in attics are handicapped, sometimes more than 20dB, by the building materials that surround them.
Most amplifiers will be overloaded with the signal levels shown on your TVF Report. As a rule of thumb, never install two amplifiers in the same system. (The amplifier in your MANT410 counts.)
The stations to the west are too weak to receive without looking in to higher antenna elevation. Unless you are a sports fan needing (wanting) access to alternate feeds, I suspect there will be a great deal of programing overlap. You can experiment with different antenna mounting heights to see if the signal strength will change much.
